24v LiFePo4 battery bank.
600Watt of solar panels
Victron 150/45 CC
It was a nice sunny day today and on my way out the door to my vehicle I decided to check on my system to see how much power it was bringing in. The app said 0W. Shocked, I checked the battery status 39%. It should be pulling in ~400W at that time of day. I didn't have time to troubleshoot then, so I switched off my array. This evening when I finally had time to troubleshoot the system i discovered the voltage from the array was about half of what it should be. I have six 12v panels wired in two 3-panel strings, then wired in parallel. Typical array voltage is ~60v at peak solar. This evening with a sitting sun, the array, unplugged from CC, was 52.2 volts. When hooked to the CC it was 25.xx volts. I unplugged each string of 3, and tested the voltage 52.2V and 52.8V. I placed one string at a time in the combiner and tested after the inline fuse. Each string read the same voltage previously stated. I left only one string connected and tested at the CC. It was half the voltage. So I swapped out the 1st string with the second string. Same issue, half the voltage. I then broke out some extra wire i had laying around and bypassed the inline fuse, and breaker switch and went straight to the CC. Same issue. Half the voltage. What gives? Is my CC shot? Is there something wrong with the panels?
Any suggestions for testing would be appreciated. I have an old junker CC that was given to me. I will see if it can charge my type and voltage of battery with it. It could be a good test to isolate the problem down to the Victron CC.
Victron 150/45 CC
