SoCalKevin
- Apr 10, 2022
- 83
But, he's got the 12 volt version, not the 48 volt version.
So he's pulling something like 450+ amps surge from packs that are rated at 200 peak amps each?
With some luck that might work, but if one pack has slightly lower internal resistance, that one is going to trip for over current, then the load all falls to the second pack and it obviously trips over current.
OP, your old batteries probably don't have a protection circuit (BMS) built in, so yes they do fine.
In my opinion you didn't do enough research and bought batteries that need to run at 120% or more of their rated current to work. Or you need a third.
But, Richard from signature is right, try full charging them a couple times. You might get that extra bit you need.
Thanks for the informative reply @400bird
But if that surge is only .5 second or so, is it really that big of an issue in the grand scheme of the battery life? Once that quick surge fires up the compressor, the draw goes way down.
Yes, i will fully admit i am newer to this and my detailed research may have lacked for sure. I saw 200a max discharge and assumed (we know that never goes well) that 2 of them would have me at 400a and id be fine. Ooops. I most definitely dont have room for a third,
As for fully charging them...
Theyve definitely both been fully charged via the charger from Signature Solar before i installed them.
But for cycling. Do you mean drain them down as low as possible and charge them again?
Thanks
