EG4 lifepower 4 - new and un-resettable error
sday
oregon
Coming from 2 EcoFlows I decided to try out the EG4 3000 and Lifepower 4. After install I adjusted battery type to EG4. System charged up battery to 100% and alarmed, disconnected. Read forums and connected BMS_test. firmware current at 3.37 and error reports as "Charging MOS fault alarm". More forum reads but no idea how to fix. I tried reseting the battery both while connected and disconnected from inverter and the run light illuminates momentarily and immediately an alarm code.
Cell_6 is showing red at 3.397v and max_diff is 0.052.
That's all I got. Any suggestions for this newbie?
Thanks
-Steve
Sounds like you’ve done everything you can without contacting the factory or your distributor for warranty service.
I submitted a trouble ticket, so we'll see how that goes. Thanks
BMS_test software. "Config" tab. Enter 888888 for the password. In the "Reading and writing MOS adhesive fault codes" box on the lower right of the tab click the "Read" button. The value returned should be "00"
take a look at these posts:
