This is a pic of a blue sea classT with cover ,a 5 post Marinco BEP ( neg batt bus ) with its type cover.. …….and the clear ones are what I made for the 712 shunt and the 2 blue seas 8 post distribution buss bars out of 1/8 inch plexi cut to size needed..the stand offs are thick wall plexi tubing cut to fit the inside and 4 inch screws .. the are very strong and solid..No wiggle at all..I’d be interested of pics of the cover you put together.
Battery fuse is in series with the shunt. So, how does it hurt if put before the shunt. Same current would still flow through them both.
Just fuse both +Ve and -Ve (not approved / not acceptable in some jurisdictions and/or applications) if it does not go against local standards.If fuse was put between battery negative terminal and shunt, then if fuse blows, inverter sees Bat+ on it's positive input and shunt input is at -48V (assuming 48V system) relative to all other inverter connections.
If fuse it put between battery positive terminal and inverter positive input, shunt on battery negative terminal, then if fuse blows inverter sees Bat- on its negative terminal, shunt and all other inputs are 0V relative to Bat- and each other.
Depending on electronics design, having any inputs outside the range [positive input, negative input] can cause damage by backfeeding semiconductor inputs. Especially if those inputs are designed for say zero .. +5V, and you apply +48V or -48V.
Hopefully designed with high value resistors in series with both shunt inputs to protect electronics, but I have no idea what they did.
With Class T fuses and holders that are 7 inches by 2.5 inches by 2 inches, double fusing becomes costly at $100 per fuse and holder and impractical, that is without adding in the cost for the 4/0 and 2/0 wire and lugs.Just fuse both +Ve and -Ve (not approved / not acceptable in some jurisdictions and/or applications) if it does not go against local standards.
He has two batteries. I have 2 and no bus bar. 3 or more should have bus bar for Battery Minus.No reason not to mount smart shunt on -ve busbar. Victron website has sample designs/drawings with smart shunt mounted on -ve busbar.
Bus bars do make for easier maintenance and adding new loads. Stacking terminals on battery posts seems so crude once you get accustomed to bus bars. BTW my shunt is mounted on my neg. bus bar. Although not as clean as a nice factory made set, I make my own bus bars.He has two batteries. I have 2 and no bus bar. 3 or more should have bus bar for Battery Minus.
Correct. Same here. I don't support fusing of only the negative.Another reason for not fusing only the negative side with the normal negative ground build is leaves open a possible return route through chassis ground depending on how the system is wired. My RV is, and probably every RV and car out there is full of these paths if only the negative is fuse
I know what a lynx distributor is. I can't imagine using it like that. It's like you don't care the use the fuses.
