ArtieKendall
I've finally got all my components and I'm getting ready to connect them. I have a question about the Victron Smartshunt.
The manual says to connect the shunt's little power wire directly to the positive terminal of the battery. Is that really necessary? I understand why there can be nothing between the negative terminal of the battery and the shunt; you want every electron to pass through the shunt.
But for the power wire, all it needs is power, and I don't see why it needs to be direct from the battery terminal. It would be more convenient for me to connect it to a busbar on the other side of the class T fuse from the battery. It will still be getting power from the battery unless the class T fuse melts.
Am I missing something?
