KevinC_63559
Quick question folks... when I think of a bus, they can usually be daisy-chained. Is this the case with the Victron VE Bus?
Specially I have (2) Multiplus II's pre-configured (Thank You CurrentConnected) to run as a pair in 230V mode. Do I daisy chain the two units together and then tie the end unit into the Cerbo, or do both units need to be connected directly to the Cerbo? Hopefully the prior...
