I have not started to look at the ANT BMS. I don't have an example of the BMS to do testing with and all other users that has one does not seem to be able to connect the BMS to their controllers or PC. If we can solve that it should be fairly simple as the ANT protocol is about 90% to what we use for the LLT/JBD BMS already.any news for ant
No it should all work fine on Python 3. The driver was written on Python 3. I had to add backfills in to make it work on Python 2.8 when I first moved it to the VenusOS.Python 3
No it is not currently on the list. If you can find the protocol spec, then you can open a ticket with the spec and we can see if there is any interest from users.Louisvdw, is your driver supports Heltec (JK) BMS ?
No not at this moment.
It does have RS232 and RS485 serial connection options, so it should be possible.
I you can find the communications protocol for the BMS, then create a ticket in GitHub for this BMS and upload that doc. If there is intrest for other users we can add it.
I assume your issue is that your Daly is not picked up?Im still having issues daly smart BMS
Ok found the files now need to download!!I assume your issue is that your Daly is not picked up?
Do you have a 3/4 cell Daly? They use other commands and I still have to implement them. The 8sell and more will work.
You will have to look at the log files. If you do not want to use SSH, then download FileZilla and use SFTP with the SSH details and copy the log files to your PC. See troubleshoot for which log files to look at.
click the troubleshoot link in my previous post. It give the details for the log files you are looking for and what to look at in them.no idea on where the log files are now
hehe.. how to look at them, that's my problem (sorry) i have them on screen just need to view or downloadclick the troubleshoot link in my previous post. It give the details for the log files you are looking for and what to look at in them.
I was able to connected to the BMS via isb interface with their sw without issues. I can do some test for you as well.I have not started to look at the ANT BMS. I don't have an example of the BMS to do testing with and all other users that has one does not seem to be able to connect the BMS to their controllers or PC. If we can solve that it should be fairly simple as the ANT protocol is about 90% to what we use for the LLT/JBD BMS already.
