Louisvdw
- Dec 18, 2020
- 166
If you don't want to use the battery as the monitor, then you have to change the Battery Monitor setting to something else like the Multiplus. What is selected in there will give the system the SOC value.I just want to use the Cerbo integration to monitor and datalog my BMSs.
However what you are seeing is what the BMS is trying to tell you. That there is an issue and because of that the charge state had to be adjusted. It's better to fix the cell with the issue than to tell your system to ignore it and use another SOC value. The reason you ask the BMS what the SOC value is, is that it know about the values of each cell. Your inverter will not know that and will only have the total battery voltage to work from and an energy counter.
