Here is the link to what I bought https://www.amazon.com/gp/product/B09TDKWBT7/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&th=1
The question is did I get what I paid for or is this a bait and switch. I will do a capacity test soon and let you know what I find.
Ok so I made my first battery purchase from VNSZNR on Amazon. Needed 100Ah with a 1C continuous rate with 3C impulse rate. The plan is to use some for solar RV power and some for a 48V system to power an EV. So I get them in and they are all within .1V of each other and I start looking at the QR codes. The codes say the battery is an LF90K nominal 90Ah battery not 105Ah. I believe there is a newer version of this battery called an LF105K but not 100% sure. I have
Attached is one of the QR codes that says.
02YCB64229000JB3D0004539
This sight will decode the serial # and tell you what it is you got. https://www.gobelpower.com/lifepo4_decoder.html
What it found is this
Code Check...
Code: 02Y-CB-64229-000JB-3D000-4539
Code seems right.
Code length is right.
Manufacturer: EVE Product Type: Battery Cell Battery Type: LiFePO4 Nominal Capacity: 90Ah (LF90K) Nominal Voltage: 3.2V Production Date: 13/Mar/2021 Manufacturer Website: https://www.evebattery.com
Code Check...
Code seems right.
