sunshine_eggo
Happy Breffast!
I’m not saying you don’t need to balance , occasionally , you do , once on receipt , and occasionally 1-2 times a year.
I would argue that 1-2 times per year is completely unnecessary if you engage the BMS in regular passive balancing at the typical > 3.40V/cell, 30-70mA balancing current.
Fractional C usage LFP tend to generally stay in balance.
This depends solely on the relative rates of self-discharge. If they are different, they will go out of balance at that rate, regardless of "C" rate.
The fact 14.2 14.4 setpoint is irrelevant, lithium’s can be charged to 95% on lower voltages ,
Correct with context, and it depends on the user. Charging to 95% SoC at lower voltages takes a long ass time: 6 hour absorption @ 3.4V/cell. If running on a generator, someone's going to be pissed.
In the battleborn case if you have a cell reaching the cutoff point but exhibiting 50 % soc you ineffect have a failed cell. , and very few passive balancers could handle that level of imbalance anyway
Nope. User recovered near full capacity by holding at 14.2V for a week. BB won't balance below 14.2V, and the user never engaged balancing over 3 years of use. I don't know the specs, but I suspect the BB passive balancing is more robust than your typical 30-70mA BMS.
The typical audience here:
Those buying low-end battery packages at $400-500/100Ah 12V
Those building DIY batteries from gray market cells.
Cell imbalance that impacts normal use is commonplace.
