Hoping you guys can help me understand a couple of things!
I have a Victron 75/15 solar charge controller that I know I undersized the output wires for (16AWG). I will be upgrading that soon to 10AWG (although I've found only 12AWG actually fits in the controller), and probably the whole controller to a 100/20 as well since I've added another panel (300W total).
I want to understand 2 things:
1) It seems like electricity flowing doesn't work quite like water flowing in a pipe. A very short length of thin wire (for ex a fuse) does increase the overall resistance a tiny bit, but it doesn't seem to restrict the flow for the overall length of the remaining wire, if the rest of it is thicker. Is this correct? So I could attach a small length of fused 12AWG to the output of the controller and then link that with 10AWG or thicker to the battery?
2) Right now with the undersized controller to battery wires, the controller is seeing a higher voltage on the output (battery) than the rest of my system. For example, the controller is reporting the battery voltage at 14V while charging at 160W. The rest of my system (based on a simple voltmeter reading) is actually at 13.5V, and my battery is maybe at 13.35V. I assume that the thicker wires I go, the less voltage will "build up" at the controller along the wire on its way to the battery. Is this correct? In my current setup, how much of that "14V" is lost to resistance through the 16AWG wire if the circuit is actually at 13.5V after the bottleneck? If I reach the 15A limit of the controller now, it shows 222W (14.8A x 15A). Does that mean the reality is more like 13.5V x 15A = 203W?
I just wanna understand how this works! Thanks!!!
