Smasher3545
Hi everyone!
I've been watching all the solar related videos I can but the maths and planning is still a little confusing. So thought I'd post this to get some help.
What I'm planning on doing is building a DIY solar system to power 2 mini splits and an EV charger.
I live in a mobile home and can't have solar on the roof, so I had a porch roof extension built specifically to install solar panels on, but no installer will do it even on this.
I live in Texas were we've lost power last 2 Februaries so I wanted to do this DIY so I don't freeze during power outages.
I have 2 mini splits and a circuit to plug in my ev charger for my 2020 Nissan Leaf currently in my house's breaker panel
I was thinking of moving them to a battery pack that is charged by solar. My thoughts were to get a shed in the back yard to put the batteries and circuitry in, solar panels on the front porch roof extension, run the wiring to the back yard and the ground wire to the mobile homes breaker panel ground.
here's the details of the items:
Single zone mini split:
So what size battery bank would I need and what size solar system would I need to keep the batteries charged? Any other advise?
thank you!
- Pioneer Low-Ambient 12,000 BTU 1 Ton 20 SEER Ductless Mini Split Wall Mounted Inverter Air Conditioner with Heat Pump 110/120V
- Voltage of 110V - 120V, 60Hz, 1Ph
- 10 Amp circuit
- 12 AWG
- 1070 watts
- The unit uses soft start technology, and ramps up to rated power depending on indoor setting. My unit starts at 300 watts and ramps up slowly to about 750-790 depending on temperature. When the first apply power, it will ramp up to the maximum, then reduce to rated. (max 1000 watts).
- SEER = 20
- Pioneer Multi 27000 BTU 3 Ton 22 SEER Triple (3) Zone Wall Mount Air Conditioner Heat Pump Ductless Mini Split, 208/230 V
- Voltage: 208 - 230-Volt, 60 hertz, 1 phase (standard household 2 line power, l1-l2-g)
- 30 Amp circuit
- Depending on the demands, this unit draws between 670 to 3210 watts in operation
- 980 watts per head unit, so with a triple zone, it would be about 3kW at most, when running at max capacity.
- 10/2 AWG wire.
- SEER = 22
- 50 Amp circuit breaker currently installed in house breaker panel
- 220v
- 2020 Nissan Leaf
- 6.6 kW onboard charger
thank you!
