I believe yes, SOK closed loop with Cerbo.If I'm right, it would affect all chargers active at the moment.
SOK closed loop with Cerbo?
VRM shows?
I don’t have VRM yet.
I have not checked. Now that I’m back in state I will dig in. I’m in houston for a few days but after I will spend a morning out there.It almost looks like the kind of thing I would see with my system when that one Pesky EG4LL battery pack would lose balance on three cells. As soon as a load hit the whole pack voltage would dive then come back up to some high voltage number.
Have you checked the individual cell voltages?
On the Cerbo, if you are closed loop with the SOK rack, you should see it as a device in the console menu.Though why unbalanced for so long?
Under Details >, do you see something like this?
Just before the voltage jumps, if you can watch this screen, you’ll see the lowest/highest cell voltage start to separate.
Also check to see if it blocks charging.
You may be able to catch it in the act, so to speak.
Not having VRM makes this challenging, I assume there is no internet.
That menu wasn't the SOK, that was my screen for the EG4-LLs I have.I'm glad to the the SOK report min/max values
I was asking Bluedog if he has a similar screen on his system. Updated post for clarification.
