Bluedog225
Texas
- Nov 18, 2019
- 2,921
I’m trying to commission my system. I’d appreciate some help with a couple questions.
Is the AC output on a Victron Quattro internally fused in the Quattro? Or do I need to run the AC out to a small breaker box and then to my quad box? I don’t expect to do anything stupid but you never know.
Can I run the AC out from the Quattro just using regular 12/2 Romex? Wiring it like a traditional AC system in my old 1950s house? All these lugs and crimps I’ve been doing lately have hurt my brain. Just loop the copper on the stud and tighten?
What’s the easiest/cheapest way to precharge the Quattro capacitors? I’m powering off a 48 volt SOK rack. Or do the SOKs have precharge built in? I’ve got no capacitors. But I have some romex and light bulbs. Do I remember a pencil can be used? I will try to find the manual and check.
I’m moving a victron 150/35 mppt from 12 volts to 48 volts. If I hook it up to the battery first, will it automatically reset?
Many thanks
Tom
Many thanks
Tom
