Bluedog225
Texas
- Nov 18, 2019
- 2,959
I’ve got a little 12 V system with a 200 amp SOK battery for my shop lighting as an interim measure until I install my big system.
I went ahead and got a 1200 watt 12 V inverter. I can run my little stuff on it and maybe I can run a few small power tools on occasion.
I’m confused about running wiring between the inverter, charge, controller, and the battery.
At 1200 watts (discounting larger surge) it’s about 90 amps to the inverter. And 40 amps(?) [edit-oops. 20 amps] give or take coming from the panel or two I will use to keep this battery charged up.
Those little Amazon bus bars are rated at 180 amps total and 15 amps per connector. Note they have one a large lug and a bunch of little studs.
Seems like I need to stack ring terminals somewhere. I can stack a couple on the large lugs on the bus bars. One going to the inverter and one going into the charge controller. Or I can run dedicated lines between the inverter and the battery in separate dedicated lines between the charge controller, and the battery. This would stack my ring terminals on the battery stud.
Where do I get a larger bus bar that can handle 100 A per connector. And where would I find one of those?
Sorry for the long post and thanks. I’m new to this whole bus bar thing.
