Rural living
- Nov 16, 2019
- 1
Hi,
I have 6 modules of panasonic NMC cells. Every module contains 12 cells that are arranged 2 in parallel and 6 in series. (the modules comes from an Volkswagen e-up)
The recommended cell voltage is min/max 3.0-4,1. Nominal voltage 3.6
The 6 moduls will be parallel connected. Max input charging 1000 watt, Max output 2200 watt. So not more than 366 watt from each module.
I wonder if someone know a good BMS for the job
