KBurns
- Jul 4, 2020
- 9
Hello, I've been signed up for a little while, going through some of the categories, and still feel like I'm reading a foreign language. I'm not sure which question to ask first, so here goes.
Will recommended these wires on his web page, but I'm not sure if those are the sizes I will need. Plus, with this crazy world we're living in, I'm kinda in a hurry just to get everything I'll need into my possession.
Wires:
The system:
HYBRID LV5048 Split Phase 120V/240V output 5kW 48V
I had a difficult time finding, then deciding which numbers to use from the specs from the inverter box.
Two batteries:
Twenty solar panels:
Rated Power: 250W
Open circuit voltage (VOC): 37.6 V
Max power voltage (VMP): 30.3 V
Short circuit current (ISC): 8.85 A
Max power current: 8.27 A
Power Tolerance 0/+3%
Maximum system voltage: 600V (UL)
Fuse Rating: 15 A
I also had a hard time trying to figure out which set of numbers to use on these panels.
On his recommendation I also bought these things:
MM400 Multimeter
CL380 Electrical Tester
If anyone finds it easy to know what else I might need without having to be in front of this pile, please chime in. Also, I might have more than I need. After looking at a thousand videos and articles, (and still don't know what the heck I'm doing) I've come to believe my panels will have to be laid out 4 together in series, and then have those 4 in parallel. If that sets anyone's alarm bells ringing, please chime in
Also, I don't know if I'm counting right, so maybe I have too many volts?
Thanks
Wires:
The system:
Two batteries:
24V – A123 LiFePO4 Battery Box – BigBattery.com
bigbattery.com
Rated Power: 250W
Fuse Rating: 15 A
MM400 Multimeter
Thanks
