I have a Basement Watchdog sump pump with sump pump controller and charger connected to a 12V AGM battery. The charger is rated for 1.6A and does a bulk charge to 14.4V. I want to monitor the SOC of the battery but also the voltage across the battery terminals. If I connect the shunt (on the -ve side of the battery) with the + wire from the meter to the +battery terminal, what voltage is the shunt reading? When my charger is recharging, is it reading the "recharge voltage"? When the charger is not charging is it reading the battery voltage? The reason for all this is that my battery specs say to recharge at 14.7V while the charger for the BW controller charges at 14.4V. The battery manufacturer indicates that if the battery is consistently undercharged, it will sulficate and fail prematurely. This is a well known and reputable battery manufacturer that produces deep cycle AGM batteries.
