I'm installing a security camera system, and need to run a whole bunch of 12 volt and ethernet wires , the ethernet and power will be running through two separate conduits, from a box on the wall, into the ceiling. I finally convinced my wife to let me do this, under the condition that there's no wires zip tied through a wall stuffex through a hole drilled in the ceiling and filled with RTV. ? Point is, I want it to look as good as possible.
What is the cleanest way that I can run two, relatively thick (1.5 inch, room for more wires later) pieces of conduit through a ceiling and still have it look decent, and block airflow from the attic to some degree?
I've been looking at different products on Amazon, but the product pictures of course always make them look really good, I was wondering if anybody had personally used something and if they liked it. I would prefer not to run wire through the wall into the attic either, it's an insulated wall, and I'm terrible at running wire.
