I have a Long Wei DC Power Supply PS-3010DF. With a setting of 3.40 volts (no current setting) and with 14 awg cable, banana plugs on one end and crimped ring terminals on the other end (battery) it works fine. The screen shows Constant Voltage of 3.41 volts and variable current of about 2.67 amps. Voltage measured at the terminals (not the busbar) is 3.32 volts.
If I add beefier cables (6 awg) with appropriately sized ring terminals on both ends, the power supply immediately changes to constant current. I don't understand this.
To complicate matters, any Constant Voltage setting over 3.49 volts causes the power supply to switch Constant Current no matter what cables are used.
I don't recall having these issues when I used the power supply a few years ago to top balance 8p 280Ah cells. This time it's 9p 280Ah cells, which is the first set of 18 cells to be charged.
No, I don't want to charge the cells using the BMS. I prefer to do the old school Top Balance.
