soylentgreen
- Apr 23, 2021
- 96
I have one of those "plug N play" hot tubs that can run on 120VAC - it heats at about 1KW.
I realized after some energy auditing that this tub is using about 150 kWh/month (roughly 100 summer, 200 winter).
As a test, I tried putting it in Eco mode, which drops the temperature from 104F to 84F. I was expecting it to use less energy, but I was shocked at how much less:
It went from using about 3kWh/day to 300 Wh/day, a 90% decline, or a reduction to 1/10th of the energy use.
In hindsight, this makes sense: this time of year, ambient temperatures are in the 70s to 80s, and the tub is in direct sunlight for a few hours each day.
Naturally, I don't use the tub much in the summer, but I also don't use it that often in the winter: perhaps 2-5 times per week.
So I had an ephiphany: if I wired the tub for 240VAC, I could keep it at the low temperature (84F) year round, and only heat it when I planned to use it.
On 120VAC the tub takes about 16-20 hours to heat up, which makes the "on demand" plan silly. But on 240VAC the tub will heat up in about 4 hours, which is much more practical.
Now, I'm not expecting a 90% energy reduction in the winter, but I am curious how much I will save keeping the tub at 84F instead of 104F come wintertime.
