Add a Heat Pump?
I'm curious to see how efficient the Natural Gas solution will be!
I just read that a heat pump is a bad idea since hot tubs usually sit around 98 degrees and in the cold winter, there's no way it can pull enough heat out of the air.I’m sure NG is more efficient. I heat my place in MN with NG.
But I’m going all solar electric off grid eventually (at a warmer climate) and would like a hot tub. So I will look into heat pump to supplement.
Well, I know some heat pumps have the “hyper heat” function that heats up water heaters.I just read that a heat pump is a bad idea since hot tubs usually sit around 98 degrees and in the cold winter, there's no way it can pull enough heat out of the air.
if you lower the kw of the heater, wouldn't it have to run more often to keep the temp of the water high?My wife loves her hot tub. I sometimes join her. It is definitely a electricity consumer. I think I figured it out to be around 3.5 kwh to 4.2 kwh per day. The 240 Volt 6kw heater was brutal so I rewired the hot tub heater to run on just one leg at 120 Volts. This made the heater more manageable at 1.5kw. When she gets in the hot tub and runs the jets it pulls enough power that it kicks on the other 4400 watt Inverter. I have two Inverters with one running all the time and the second turning on when the power load gets above 75%.
I considered all sorts of alternatives such as running a heat line from the wood boilers and such, but this approach works great, and it allows me to run the hot tub on Solar.
Yes, that is absolutely true. My wife's Hot Tub is one that has a seperate Circulator Pump that runs 24/7. That is the Pump that is used in the heater loop. The Jet Pump is a seperate 240 Volt pump so with my wife's Hot Tub the answer is no since the Circulator Pump is running all the time anyway.if you lower the kw of the heater, wouldn't it have to run more often to keep the temp of the water high?
Ha! I love itBeen there, doing that...
"Hot tub" is a 100 gal. Rubbermaid cattle trough:
Paloma PH6-DP I already had as I use those in the field to generate hot water to locate cold water slab leaks with an IR camera.
2 small 24VDC pumps from Amazon. The Paloma main burner will ignite at 4.6 PSI, so they are enough. 34W power to run them.
Buncha hoses and other crap. The "bubble wrap Mylar" around the trough keeps temperature loss to a minimum. Drops from 110 to 70 overnight with ambient low cold temp around 17. I can't afford the gas to keep it hot alla time, but if you start at 70, the Paloma has it up to 100+ in less than an hour.
All runs off of an old 80W SOLEC panel.
During warmer weather, I replace the Paloma with passive collectors made out of a 100' length of .7" drip tube coiled up in a frame. From April to September, I don't need the Paloma.
At night, I have to disconnect and empty the Paloma, but that takes < 1 min.
The remote temp sensor reports back to the Oregon Scientific weather station inside.
It's truly incredible how cheap the small demand water heaters are now. That Paloma was several hundred $$ when I bought it in the 90's.
Your setup is nicer, and automated. Cool.
Build a greenhouse around your hot tub and you get double the bang for your water it
Propylene Glycol Antifreeze/Non-Toxic Antifreeze to keep the hot tub’s pipes from freezing during the winter. This is a very specific type of antifreeze that is sold for hot tubs. Do not use the type that you would use for your vehicle as it is toxic.
I love the irony in the naming here!The best propylene glycol antifreeze on Amazon is from Engine Ice.
I have a hot tub and have been thinking about how I could use it as "storage" to dump my excess solar energy during the day, instead of net metering or storing it in a battery.
All you need is a line blower and some antifreeze, both of which should cost about the same amount as a single opening or closing. It's really easy to close a spa yourself. You could probably get by with something smaller and cheaper if it's only for a spa as well. They also come up on eBay periodically, especially mid-season (middle of winter, or middle of summer).We paid "pro's" last year to winterize it. I could have done a better job. They didn't drain the ozonator/UV box so it froze and broke. Then they couldn't come up with replacement part, even though they're the ones who installed it (it was a replacement/upgrade when the original ozonator failed), and I wasn't even trying to make them pay for it.
That'll help a lot. I've been adding 2 inch pink panther FOAMULAR board foam.I have a thick cover, but not a floating one. I added a lot of insulation between the fiberglass and the wall of the hot tub. Just went to Home Depot and picked up some rolled up home insulation.
I came to the same conclusion in my testing. mine is ~1200 watts but I consider it more "supplemental power" kinda keeping it the same temp it already is atThis made the heater more manageable at 1.5kw.
