Overtaxed
It's not the utilities who get screwed, it's less well-off renters and others who can't install solar. They pay extra to cover the freeloaders. It's not noticeable when rooftop solar penetration is only a percent or two, but the scheme inevitably breaks down as penetration grows.
Exactly. The more of us who install solar, the more costly power becomes for others. And the more of us that disconnect, the more costly the grid becomes for others.
You can only claim the federal solar tax credit once. If the taxes you owe are less than the value of the credit, you can roll over the remainder towards future income tax burdens.
Once per install, right? If I put up 10KW of panels this year on the house, then another 10KW next year, I believe you can claim it for each install on the same property.
There are several issues with the above.
Both are good points, however, in some areas (like mine), it certainly seems like the power company is doing everything they can to stop solar. In my area, they require you to move to TOU rates if you have solar; super off peak (around 6 hours, IIRC) is less than my current rate, everything else is higher to MUCH higher on the TOU plan. So, sure, I can do it, but without batteries to peak shave, it might wind up costing me more for less power consumed, in fact, it almost certainly would because the on peak and critical peak rates are so much higher. Also, they prohibit charging (I couldn't find this is writing, but all my calls to Duke they said the same thing, you cannot use our power to charge your batteries); I have no idea how they'd know, but, if you charge using their power during super off peak, you risk disconnection (again, I couldn't find any verbiage to this effect, so maybe it's make believe, but in my many calls to them, a few people said "No charging").
It's kind of a "heads I win, tails you lose" plan. Sure, I can cut down on the number of KW consumed, but I'll pay more for each KW. Duke would love that, I'd be putting in solar to their benefit rather than my own?!
