Hi Guys,
Getting all my parts together for new solar setup in UK... would love to hear some advice on choosing a bms...
I have purchased the inverter off grid 5kw https://voltaconsolar.com/off-grid/conversol-v7-off-grid-inverter.html
its got a BMS port directly on inverter : ''BMS communication port: CAN and RS232 or RS485 ''
I understand CAN / RS232 / RS485 is type of cable/protocol for BMS communications...
Im looking for a BMS , I don't want to spend more than £200 that will communicate with inverter.
Im buiding a DIY battery bank 48v using Lifepo4 cells (16 units 3.2v 280ah)
My load will be initially 1200w- for as long as possible, maybe more watts in future .
Initially I did some calculation
Inverter 6000W / 48v = 125A BMS, + 30% headroom 162.5A - which puts me upto 200A BMS - however reading online someone said if your buying a cheap BMS just buy the max Amp possible - even double. With this in mind I was looking at the 250A BMS.
I was looking at this BMS:
250A 16s 48V
Daly one:
What does ''common communications port'' and 'separate port' mean exactly - I think common means it charges and discharges over the same cable?
whats the advantage/disadvantage of this? - is my inverter compatible?
I will be using the batteries while they are charging so dont want to have to switch between the two if thats what this relates too...
Any other compatible BMS unit you can recommend that are available in the UK?
Thanks Guys!
250A 16s 48V
Daly one:
Daly LiFePo4 48V 16S 80A-250A Smart BMS Bluetooth (Fan) Common Port with Balance | eBay
(Lifepo4 16S 48V 80A-250A BT BMSï¼Fanï¼. 1 16S 48V BT BMSï¼Fanï¼. Battery Typeï¼Lifepo4. Bluetooth moduleï¼. 1 Bluetooth module. Sound & Vision. 4)Over heat protection. 5)Short circuit protection.
www.ebay.co.uk
Thanks Guys!
