shavermcspud
- Mar 12, 2020
- 607
I have had very good support from them, as above I spoke with Link.
Someone Send him Link’s number. Can’t seem to find it in this phoneI have had very good support from them, as above I spoke with Link.
Yes please share it. It would be nice to have a number to call for support. Seplos is trying very hard to get a US distributor, so I hope that happens soon, so we can get a warehouse and support here.Someone Send him Link’s number. Can’t seem to find it in this phone
I don't have his number i spoke via emailSomeone Send him Link’s number. Can’t seem to find it in this phone
I don't quite understand how the JASSN Bus Bars are intended to be used. If I'm reading correctly the breakers are rated for 230/240V, but I'm assuming your system is 48VDC? Are you connecting each battery bank to their own breaker?Cannot wait to get the 280ah kits in, so I can connect all seven batteries together in parallel using the Seplos JASSN busbars.
It will be interesting to see if and how 135ah banks and 280ah banks will work together once loads and charging are applied. I may need to sport for the larger 16 port JASSN bus bars, since I am planning to add two additional MPP Inverters once I move south. I think 1380AH should do it?
Those breakers work for both AC and DC. Yes, each battery positive goes to a breaker. But now that I have 7 batteries, I will need to purchase the larger JASSN.I don't quite understand how the JASSN Bus Bars are intended to be used. If I'm reading correctly the breakers are rated for 230/240V, but I'm assuming your system is 48VDC? Are you connecting each battery bank to their own breaker?
so this is not the seplos box ?made this custom case on alibaba.. cannot wait to receive it
180 USD its for LF280k EVEso this is not the seplos box ?
what is the retail price for this box, and where did you order it?
moq is 5.180 USD its for LF280k EVE
shipping arrount 100 usd for 5 boxes (My own freight forwarder)
i asked a company on alibaba specialized with metal boxes to make them
Shenzhen Jiayi Technology Co., Ltd.
Shenzhen Jiayi Technology Co., Ltd., Experts in Manufacturing and Exporting and 168 more Products.cnszjiayikj.en.alibaba.com
No located in Lebanonmoq is 5.
wonder if this fits the 304's , just like the seplos one.
since i already have the bms...
this would be a nice option.
are you located in the eu ?
Great, in fact if you add the connectors, cell insulation, cell bus bar, flexible bus bar , fuse support , fuse, and some other accessories, you get the same price or more than seplos case. Now we have 3 different option for seplos bms case : seplos, amy and this one.No located in Lebanon
shipping to Lebanon is 250 USD per cbm.. each box is arround 0.1 cubic meter so shipping would be 125 usd
i heard that the 304 and the 280 are nearly same dimension so they can fit
remember these are custom and not premade ..so they can be edited
i just gave them the dimension of the the lf280 and the 3d file of seplos bms and screen
and they made it from scratch
180 is the price of sample.. they can go to 130 if its a huge order
if you want to order just tell them you want the same box Mahdi did..they have the 3d file....so you dont need to provide them one
moq is not 5.. but they wont do one for cheap. You can do a group order (you and people you know )
i have orderef these too from here
Ip67 Waterproof High Current 200a Energy Storage Connector For Lithium Battery - Buy Ip67 Waterproof High Current 200a Energy Storage Connector For Lithium Battery,Connectors For Energy Storage Systemr,200a Lithium Battery Connector Product on Alibab
Ip67 Waterproof High Current 200a Energy Storage Connector For Lithium Battery - Buy Ip67 Waterproof High Current 200a Energy Storage Connector For Lithium Battery,Connectors For Energy Storage Systemr,200a Lithium Battery Connector Product on Alibaba.comwww.alibaba.com
This is great to now have all these options! $400 for the Seplos comes complete with everything except the cells, including BMS and display, and all the busbars, hardware, insulation, and vibration dampening isolation foam for the cells. And they can be stacked and connected together via the smart BMS to balance the cells and loads across batteries. Much nicer, cleaner, and more professional looking as an ESS for Solar.Great, in fact if you add the connectors, cell insulation, cell bus bar, flexible bus bar , fuse support , fuse, and some other accessories, you get the same price or more than seplos case. Now we have 3 different option for seplos bms case : seplos, amy and this one.![]()
You might want to double check that Seplos price. It's not $400. My quote delivered to US w BMS and whole kit is more than double that.This is great to now have all these options! $400 for the Seplos comes complete with everything except the cells, including BMS and display, and all the busbars, hardware, insulation, and vibration dampening isolation foam for the cells. And they can be stacked and connected together via the smart BMS to balance the cells and loads across batteries. Much nicer, cleaner, and more professional looking as an ESS for Solar.
Sure beats a wood box with threaded tension rods and an open top!
Perhaps they raised it?
Thats what I paid. $350 for the kits without BMS, and $400 with a 200amp RS485 version BMS. These additions will make seven total Mason kits I purchased(including 3 x 200amp BMS's, 4 x 100amp BMS's, and a JASSN busbar), so I may have gotten a discount. Shipping was extra, so the total for three additional kits shipped was $1355, so shipping was $255. Pretty reasonable.You might want to double check that Seplos price. It's not $400. My quote delivered to US w BMS and whole kit is more than double that.
I still didn't test the RS485 version with my mpp solar inverter. Did you try ? I put it as second priority bcoz I switched to DEYEThats what I paid. $350 for the kits without BMS, and $400 with a 200amp RS485 version BMS. These additions will make seven total Mason kits I purchased(including 3 x 200amp BMS's, 4 x 100amp BMS's, and a JASSN busbar), so I may have gotten a discount. Shipping was extra, so the total for three additional kits shipped was $1355, so shipping was $255. Pretty reasonable.
i did and do, seems to work well here so far, but still testingI still didn't test the RS485 version with my mpp solar inverter. Did you try ? I put it as second priority bcoz I switched to DEYE
Ok, it is the pylonthec Rs485 comms implementation to mpp solar I would to test later.havent tested comms from the canbus tot rs485 to mpp solar/voltronic yet
using pylon on voltronic side, rm485 on seplos side.Ok, it is the pylonthec Rs485 comms implementation to mpp solar I would to test later.
Good news, thank you. That's interesting, having a mix of canbus and rs485 version depending of who is the master, the battery bank could be use with voltronic or deye inverter !! I need to ask seplos if this configuration is supported. I'm tempted to say yes since the battery inter comms is the same ?using pylon on voltronic side, rm485 on seplos side.
this works .
however, have not tested 2 bms's
1 16s bms canbus version -> 1 16s rs485 -> voltronic yet
