HKZBob
- Nov 7, 2020
- 52
Dear all,
thank you for your advise in advance. US goes green again. Looks like solar gets a push.
I using a 2000W Inverter in my RV who is used temporarly and most of the time is off by remote switch.
I am struggleing want to start a DIY project to power my RV with 300W Solar on top.
I have decided to go with a Lifepo4 12V 200Ah. I think will go with Higree cells (Soonbuy)
My choice
Now my first thought is to connect inverter direct to the Lifepo4 pack with a
Thank I have an active and passive balancer. (The active I can not use anymore. Smart BMS needs the cell voltage)
Roadblock!!!!
If I go this path low voltage protection will be monitored by my RV. It starts beeeeeping when BAT is low.
Over Voltage protection is monitored by my Electronic Block of the camper.
Do I need als the monitoring ???
I would like to understand which is your experience with high loads in your RV.
Which way did you took and and how about the durability.
My favourite is below but how can I do cell monitoring on my smart phone.
Do you know a module which makes a cell monitoring without balancer function for my mobile?
Thanks
Bob
My choice
- 200A Fuseblock.
- than to connect an 5A active balancer
Roadblock!!!!
- Or shall I buy a 200A Smart BMS and Basta. If it breaks buy an new one!!!!!
- Or shall I do with a small BMS and place a huge contacter behind it.
- but from time to time the BMS is off
- Even when my inverter is off the "Inverter Caps" will be charges and this causes heavy arcing in the contactor and kill it over time.
- connect inverter direct to the Lifepo4 pack with a
- 200A Fuseblock.
Thanks
Bob
