socratic gadfly
I am using a system design tool. When one designs a string with low voltage (eg 100v), moderate current (eg 10a), long string (eg about 300 feet), with 10 ga wire, the voltage loss is about 6%. The tool complains that the voltage drop is too high and the "string doesn't work."
I can understand that the string is not efficient, but I still have 94v at the end of the string. This is still enough volts to run the inverter. This may be undesirable, but is it dangerous or harmful to equipment?
I don't know why the inverter should care. All that it sees is 94v. As for wires heating up due to more resistance, a longer wire may generate more heat, but it has a longer distance to dissipate it so that seems to even out.
Please help me with this.
Thanks.
Thanks.
