The Story of Three Weize Battery Failures
I bought two Weize 100 Ah LiFePO4 batteries from Amazon in August, 2022. I put them in my RV, wired in parallel. When on shore power the batteries are charged with a Progressive Dynamics model #PD9100L, LiFePO4 compatible charger rated at 60 amps. When not connected they are charged by two Renorgy 100 watt solar panels connected through an Epever solar controller.
![Victron monitor 1.jpg Victron monitor 1.jpg](https://diysolarforum.com/data/attachments/226/226540-19cec564c6dab29da2058a5684046229.jpg)
The batteries worked flawlessly up until January, 2024. At 6:24 am on January 5 the batteries discharged from 13.4 volts to 13.01 volts. They were in my RV but disconnected from everything by way of a master disconnect switch. At the time of the discharge there was 0 amperage draw – there was no electrical load on the batteries. They are monitored by a Victron shunt monitor. At right is a picture of the monitor readout showing this unexplained voltage drop, as well as a 0 amp draw.
At this point I contacted Weize technical support and, at their suggestion, removed the batteries from the RV and individually charged them using another, LiFePO4 compatible charger. I charged them back up to a resting voltage of 13.43 volts, and put them back in the RV.
All seemed well and the batteries held their state of charge. Nothing was used electrically. Then, on the morning of January 8, the batteries again mysteriously discharged, again with no amperage draw. At right is another picture of the readout from the Victron shunt monitor for this second unexplained discharge, showing a drop in voltage to 12.86 volts.
![Victron monitor 2.jpg Victron monitor 2.jpg](https://diysolarforum.com/data/attachments/226/226541-8e056e577561bcc56ba4b355e8dfeba9.jpg)
I removed the batteries, went through the same recharge procedure, reinstalled them and they again sat fine for two days. Then, for the third time they again discharged with no load on them, going down to 12.89 volts.
At this point Weize technical support told me to return the batteries which I did. They then sent me to new batteries which I received in late Jaunary, 2024.
These batteries worked fine until June, 2004 when the batteries were drained to 12.89 volts when using a small space heater run through a 1500 watt inverter. The batteries were placed on charge using the onboard Progressive Dynamics charger. One charged back up, the other stayed at 12.89 volts. Attempts to recharge this battery using different chargers failed, including trying to jump it with another battery to wake up the BMS. Again, a series of emails back and forth with Weize technical support resulted in them agreeing to take this battery back and send me another. The new (third) battery has just arrived and will be installed in the RV with all of my fingers crossed.
