Chadd
- Jul 13, 2022
- 92
Good evening Gentlemen,
Adding two JA 460 watt panels.
Max voltage 42.13 each
Max current 10.92 each
12 volt inverter so battery's are all 12 volt wired in parallel.
Am I correct in thinking I will require two EPVER TRIRON4210N 40amp /12v 780watt charge controllers ?
One for each panel, as the wattage if the panels were wired in series would be to much for one controller even given that the panels will not reach max power ?
Thank you for your time God Bless Chadd
