That is up to you, you would need more batteries to use one.Ah, I see. Yep-oops. Sorry.
So would a 48v inverter work?
Yes. You'd use the new standalone MPPT controller to charge your battery but still use the inverter in your 2724 all-in-one.Would the charge controller be for my current inverter so I can use my panels in series?
You can move to 48V if you want to spend more money on a new all-in-one and two more 12V batteries. It's not necessary. But little in life is, haha.Let's say I go with a different inverter. I'm assuming this would be a 48v all-in-one, correct?
I did the single panel experiment, pulling in nearly 200 watts from each.Yes. You'd use the new standalone MPPT controller to charge your battery but still use the inverter in your 2724 all-in-one.
You could also sell your 240s and buy a couple of 300-400s with a Vmp closer to 40V. You might even come out a few bucks ahead.
Did you do the single panel experiment?
Is the issue with my panels in parallel are not pulling over 30v? Why is 40v the magic number here?You could also sell your 240s and buy a couple of 300-400s with a Vmp closer to 40V. You might even come out a few bucks ahead.
When voltage is low, amperage maxes out before energy can be transformed to watts...Is the issue with my panels in parallel are not pulling over 30v? Why is 40v the magic number here?
the issue with my panels in parallel is they are notpullingmaking over 30v? 40v is the minimum number here because I have to make at least 20% higher voltage than my 24V batteries need to charge
30V is the magic number. That's the minimum spec for the MPPT controller in your AIO box. Your panels are rated at 30.4 Vmp in the idealized STC lab test. Voc and Vmp vary in real world conditions, especially with temperature. Look at this IV chart for a 60 cell CSUN panel that's similar to yours:Is the issue with my panels in parallel are not pulling over 30v? Why is 40v the magic number here?
Well, the most you will get out of a 24V controller with a 25A limit is 576W at 24V, 696W at 29V, but at that point, the batteries won't be drawing much... but you might have a large demand from the inverter... so 696 is the max wattage you could ever see.Thanks to Gelmjw, CuriousCarbon, DoggyDogWorld, Supervstech, 12VoltInstalls, and StuartV.
I'll be purchasing the Growatts this week, and I plan on following up with how everything is working out.
Last question for anyone willing to answer: I am pulling 415-450 (max) from my 4 x 240 (37.2A) solar panels on my PIP inverter, which has a max charging of 25A.
What might it look once I can pull in 74.v?
Inverter x 1: PIP 2724LV-MR 24V 2.7kW 120V Inverter, 600W Solar
Solar panels x 4 (used): SST-240-60P Brand : Trina Solar Wattage : 240 Watts Voltage : 37.2V ( open current )
Batteries x 4: Weize 12V 100AH Deep Cycle AGM SLA VRLA Battery
The Growatt you spec'd out can supply up to 2000 solar charging Watts to the battery (24+V * 80A). Your 4 panels are rated for 240W each, so 960W. Depending on location you may get close to 960W at high noon on very sunny, cool days with short, fat wires and perfect connections. Most of the time production will be lower, of course. You can use PVWatts for your location to estimate average production per month.I'll be purchasing the Growatts this week, and I plan on following up with how everything is working out.
Never thought about it this way. Thanks! This was extremely helpful!Well, the most you will get out of a 24V controller with a 25A limit is 576W at 24V, 696W at 29V, but at that point, the batteries won't be drawing much... but you might have a large demand from the inverter... so 696 is the max wattage you could ever see.
24P | Growatt 24V SPF 3000TL LVM - 3kW 120Vac Stackable Inverter 2kW MPPT Charge Controller Split Phas |
