withaview2
- Aug 8, 2022
- 23
Not long run at all but I have some 6awg PV wire I thought I use that6awg PV wire is way overkill unless it's a very long run. Most PV wire is 8-14awg with 10awg being the most common for the larger panels (60-72 cell 250W+).
Ok. 6awg wire and 75A fuse?60A to MPPT should be 1.25X wire rating. If it's 60A, and you're putting out 60A, it will blow. If wire rated for 60A, fuse @ 75A.
1/0 from MPPT to battery is complete overkill unless you have long wires.
Good question. 1 near positive terminal on inverter and 1 before DC>DC converter?Why does battery isolator only isolate from MPPT and not loads? Should isolate everything.
But if inverter draw max 6000W is not 300A fuse necessary?3000W/24V/.85 = 147A
I have no cables yet, but if that's the case, better to go with 2/0awg?Depending on temperature rating, 1/0 may only be good for 125A.
1/0awg @150A rating should be 200A fuse then?300A fuse should be 1.25X wire rating, and wire should be good for 147A or more.
Ok.6awg to 24V @25A fuse is overkill unless you have long wires.
Need fuse between DC-DC and fuse block.
That was my idea. I will have to check MPPT manual. Thanks for clarification.DC-DC may be more sensible off the battery unless you want to use the MPPT load ports for DC-DC cut-off, i.e., most MPPT load ports allow you to specify a minimum voltage at which the MPPT will cut power to the load ports to protect the battery. Ensure the load ports are rated for the needed current.
I'm a beginner to this so big thanks for helping out.
Other novice here.. can you provide a link to where you mocked up that diagram? ThanksHi!
I would greatly appriciate some feedback on this set-up. Should something be changed? Perhaps the DC>DC converter on battery instead?
Made with Adobe Photoshop.What software did you use to make that drawing?
Could you say as a general rule, bigger wire, bigger fuse/breaker?You can always use bigger wire. Just fuse/breaker accordingly.
I was wondering what those busbars was used for.Better to have a set of bus bars. The isolated would be between the battery and (+) bus bar with MPPT and Inverter attached to bus bar.
Ah, ok!You do not size for surge. You size for max continuous. Furthermore, if you were sizing for surge, 1/0 is not sufficient.
By meassuring on the positive battery wire?10-4 good buddy.
Lastly, assuming this is a DIY 8S 280Ah, ensure your BMS can handle the needed current. Also, I'm assuming you plan to use the BMS as a battery monitor for % charge and current. This is generally okay, but I would confirm the current measurement with a separate DC clamp ammeter before I trust it.
Will's site recommends a few good battery monitors if you want something that doesn't need a phone/tablet as well.
