mcnicholl91
I have recently had 7.2kw solar panels installed (ground mounted), a solis hybrid inverter & rosen 10 kw battery. We just moved into our self build home 6 months ago and the home is using a hitachi heat pump to supply dhw and underfloor.
Is it possible to add some kind of wind turbine or system that would be compatible?
Thanks
Thanks
