Can a wind turbine be connected to the Bluetti AC200P? I assume it can if connected to a charge controller. The charge controller has a brake for the turbine.
More wind than sun in winter, no solar at night. Built-in mppt does not have a brake to prevent overload in high wind. I know solar can be connected directly.
Installing a small wind turbine? Get the information you need for an informed decision: The good and the bad, just the literal truth to help you choose.
yeap. if you dont have wind turbines in sight from your home, is probably not worth it. not to mention that wind is mostly worth it on big scale (big wind turbines). not little 10 inch turbines attached to a pole.
