Generically, storage is best closest to 50% SOC or 3.200. Many manufacturers will set them to 3.350 prior to warehousing, hence why most LFP cells arrive between 2.390-3.300. Also when Binding/Clamping, it should be done at 25C/77F temp and 3.200Vpc. I use Maker Spec Sheet info and not prebuilt packaged companies datasheets.
Many of the offshore ones are nuts with even insisting that cells should be charged to 3.650 shortening their lifecycles intentionally. High End brands like BB, ReLion etc are not entirely the same because they are using Premium Matched & Batched cells and their have their own custom BMS' (which are over rated for safety margin & longevity) IE, their 100AH packs usually have 120AH cells.... Their 100AH BMS's are typically 120-150AH but locked down to prevent being overdriven. They do it as Warranty Safety as well to prevent ding-a-ling from getting too cocky and creating claims as a result.
