So I’m wanting to run 11-430w sun power panels with tigo in series to a eg4 18k mppt port. Its going from panels on the roof—>junction box on roof—>attic—> inside garage(inverter location).im trying to find out 2 things: if what im wanting to do is correct setup. And if so, can I run a straight line using pv wire and ground from panel/rack through junction into flex conduit(in attic) then down into trough for inverter? If this isn’t correct, could someone please explain what I’m not doing correct or if there is a more efficient way. I have no trees or anything to worry about shading so I wanted to run straight dc to inverter.
