corn18 Village Idiot Joined Sep 9, 2021 Messages 676 Mar 19, 2024 #1 Can I use 2/0 between batts and then 4/0 to the distributor? 4x100Ah batts.
Supervstech Administrator Staff member Moderator Joined Sep 21, 2019 Messages 11,560 Location Belmont, NC Mar 19, 2024 #2 You can, but there will be some voltage drop.
Supervstech Administrator Staff member Moderator Joined Sep 21, 2019 Messages 11,560 Location Belmont, NC Mar 19, 2024 #3 I like to keep all wire sizes he same.
corn18 Village Idiot Joined Sep 9, 2021 Messages 676 Mar 19, 2024 #4 I am helping another feller with his setup and he has the batts installed already with 2/0. I do what you do. 4/0 for a 12V 3000kVA system for me.
O OzSolar Whatever you did, that's what you planned. Joined Jan 5, 2021 Messages 2,693 Location Southwest MO Mar 19, 2024 #5 One reason to keep all the wires the same is in case a situation happens that requires you only being able to use 2 batteries.
SeaGal Photon Sorceress Joined Aug 17, 2022 Messages 2,642 Location UK Mar 19, 2024 #6 Supervstech said: You can, but there will be some voltage drop. Click to expand... ... I suspect that all wire will exhibit a voltage drop when a current flows... Mr Ohm taught me that one
