Zero_PD
Hi,
I have a Growatt 48V 3kw and I of course need to wire up its AC Output. I've watched a bunch of Will's videos and in a couple he cuts a power strip and wires it up, with the disclaimer that because it's only rated for 15A/1800W make sure you're not pulling more than that. Of course my Growatt can source 3000W/25A, so I want to be able to source that much without frying anything.
Problem was I can't find a beefy power strip to simply buy and wire in. I've found some welding extension cords that are rated for 3kW, but then I would have only one single input, and I need to be able to plug in a few different things (and stay under 3kw, of course).
So right now I'm thinking I:
Thanks!
- buy 8/3 cable
- wire it up to the AC output
- wire that up to 3 terminal bars
- get 2x 15A power stripsand wire them up to the 3 terminal bars. And make sure not to plug more than 15A into each.
Thanks!
