David B.
Putting together the below system. Thought I had it figured out but, not positive on the 5kw solar panel wiring. Series or parallel? Nearest panel is 60ft from inverter, farthest panel is 110ft from inverter. In full sun from 8am til 5pm in central ga. Panels set at 28 degrees. I am concerned about charging the 13kwh battery using the full 120 Amps available. I can dedicate all solar to battery but if some watts are left over that would be great. Once battery is charged house will go full solar. Thanks in advance for advice on the solar panel wiring.
Solar panels
12-415w
Imp 13.13a
vmp 31.61v
isc 13.79a
voc 38.82
msv1000v
mono half cut
inverter
ip6048
6000w
360 nominal vdc
600 maximum vdc
120-550 vdc range
125-160 startup v
2*15a mpp voltage range
21a isc pv
DC charger in the inverter
48dc
Max discharge 150a
Max charging current 120a
Battery 48 volt 13kwh lifep04 100 amp discharge, discharge locked out at 20% charging locked out at 80% so daily charge 7kwh
Solar panels
12-415w
Imp 13.13a
vmp 31.61v
isc 13.79a
voc 38.82
msv1000v
mono half cut
inverter
ip6048
6000w
360 nominal vdc
600 maximum vdc
120-550 vdc range
125-160 startup v
21a isc pv
48dc
Max discharge 150a
