Old_Skewler
Long story not so long, I didn't weatherized my Flotec Shallow Well Jet Pump correctly this winter and the body case broke ? after freezing.
The existing pump is 115V and 1/2HP, pulling about 10 FLA. The pump was already making some weird sounds so it is time to replace it, despite having found the case for about only $80. My panel is split phase and this pump is connected to one side of the panel.
My question is, after reading about unbalanced loads in split-phase systems: should I consider buying a replacement 220V pump instead of the 115V and adding a new 220V panel to the house? I suspect this would help with unbalanced loads in the panel but I do not know if worth the work.
How critical is to have the loads balanced and would this extra work be beneficial to my system? Right now I run a split phase Kohler 12kW generator and a lot of times I only have this single pump running on the system. Pretty soon I will add a Growatt split phase inverter and EG4 batteries. I don't know if the split phase unbalance is more critical on generator or inverters...
Any feedback is welcome.
