HighTechLab
AKA Dexter - CTO of Current Connected, LLC
- Sep 23, 2019
- 1,693
SMA Communication Update:
I've finally made progress, but not in the direction I had hoped. Since SMA has been giving us the run around and didn't want to work with us to fix the issue of how the inverter responds to the BMS, we have been forced to make physical changes within the BMS to address the operation issues. A new version was finalized this week and tested overseas and is now en-route to me for final testing. Once I give the final green-light, I am ordering 50 retrofit BMSs and future production will include this updated BMS.
Info regarding the retrofit / customers with existing packs and SMA inverters
- Only the master battery that communicates with the inverter will need to be updated to the new SMA compatible BMS.
- We can ship you the retrofit BMS and you can replace it on your own in-field
- We will make a step-by-step instruction and video tutorial for this.
- Your warranty is not invalidated by upgrading the BMS on your own.
- We will cover the cost of the BMS and shipping to you.
- Please email dexter@currentconnected.com if you wish to be put on the waiting list for the retrofits to arrive.
- If you were planning on adding another battery to your system, we can replace the BMS in-house prior to shipping, so it's ready to go out of the box.
- You must make a note in the "order notes" field during checkout otherwise we won't know to make this change!
