liamlunchtray
- Jan 13, 2022
- 44
Hello - I recently purchased a 2011 Born Free Class C RV with a Xantrex Freedom 458 2000watt inverter/charger. The RV is a 30amp input and the battery system is 12v, currently with 2 cheapie 100AH lead acid batts. I also have a 3600 watt generac generator. I'm having issues with the 458 charging consistently (it turns off the charger after a few minutes on shore power and allows batteries to drain) and I believe it needs to be replaced or repaired.
In the future I plan on moving to a solar/lithium setup. nothing too crazy, but hopefully around 600AH of Lithium and 750watts of solar (depending on what I can fit on the roof) My newbie (and possibly stupid) question is - Are there any recommendations for a modern pure sine lithium compatible inverter/charger that would be a drop in replacement for the Xantrex 458 that I currently have? I was thinking perhaps the Multiplus 12/3000 would work? My goal would be something that would work fine with my current setup, but not preclude me from adding solar/lithium when I'm ready.
Thanks for the help.
Liam
Liam
