XUBA batteries arrived
joeExotic
XUBA 120ah batteries arrived today. Took about two months to arrive. There's a button to push and it shows 13.3V. I kind of want to open them and look inside but not sure how to do that. The packaging was heavily padded. No nuts and bolts in the box can anyone recommend some good ones maybe on Amazon. They threw in 3 pairs of cables.
I sure would be interested in seeing some capacity test on those.
I think it is ok to connect the batteries parallel.
Check the box carefully for nuts and bolts.
If you don't find them buy stainless from ACE or some other home improvement store.
No nuts and bolts only 3 batteries and 3 pairs of cables. What size nuts and bolts?
Generally wiring in parallel is not going to be a problem .... wiring in series is sometimes a problem because of the BMS used.
These are the right size, but nobody had stainless steel so I'm going to call a bunch of hardware stores to find them now.
Is it a good idea to put a split washer on the bottom then the wire then another regular washer then the hex bolt?
So I drew a diagram of what my set up is going to be. Should I upgrade the fuse to 40A? what else should I do?
