chaosnature
- Sep 15, 2022
- 527
Definitely the inverter
sureCan you upload your YAML files in a zip file?
No solar ..its night here in uk by this timeWell it would help if you also shared the other parameters / fields ... Not sure if there is something else that we are missing.
Otherwise yeah. Solar power is available or inverter is being told to charge from the grid (maybe based on timer / time of day ???).
Do you have a minimum voltage set too high in the inverter maybe ?Definitely the inverter
Shouldn't it be Surplus Export ?The only one settings i messed with on the inverter side today is this
it was always MAximum export until a colleague of mine found that settings and i changed it to suplus - thats the changeShouldn't it be Surplus Export ?
Try Off-grid otherwise
which update version are you talking about?By the way (yes ... I'm requoting an old post) ... Did you also face issues with BLE and syssi Software ?
I know they recently released a major update that requires some re-configuration. I'm still on the old version, but my ESP32 connected via BLE report periodically "Offline" (approx 6h duration, happens every 2-3 weeks). Did you also encounter this issue ?
I initially greatly improved the reliability by essentially gluing the ESP32 on top of a Polycarbonate plate on top of the BMS (~ 30cm), so it should have excellent WiFi and BLE connectivity. Yet it drops off from time to time.
Initially I thought it was the BMS that went offline and all protections got disabled all of a sudden![]()
I think its not the ESP - srywhich update version are you talking about?
my ble connection is absolutely rock solid since days. have you set the framework to esp-idf or arduino?
syssi esphome-jk-bms 2.0.0 vs 1.5.0.which update version are you talking about?
There is about 2m between the ESP and the BMS - and the Battery is in an wooden cabinet
My other two batteries are in the basement in an metal cabinet (with open doors at the moment) and the ESP is on the ground floor and aprox 6m distance....and the BLE still works, but sometime reconnects after yome hours. So the BLE is really stronger than i thought
You are using different versions of the CAN Controller software - the newer version does not have a sbsorbtion time but the absorbtion offset.@silverstone
Help me out here
i have 2 ununiformed absorption offset (notice in the screenshot)
Absorption time is not available on the Slave ESP setting even though they are the same BMS model)
what should i set the absortion to - i just guessed
and yes the Bulk v are not the same...deliberately, bcos batt 2 was not charging and discharging at the same rate so i used that to correct the behavior and it worked
@You are using different versions of the CAN Controller software - the newer version does not have a sbsorbtion time but the absorbtion offset.
Only the set voltages in the CAN ESP that is connected to the inverter matters - the other doesnt do anything at all
There are those days ...Today is the day that nothing works for me....i am also dealing with a no manual setup of the new PB2A16S20P that came today
its not as straightfarward as the power bms,
the numbering are all wrong...no way to tell --- arrrg i am fed up
Ah, yes you maybe have to pick another BLE Protocol for some BMSs - and i´m on 2.0.0 since the release and there are absolutely no issues with the connection - would recommend you tu update and keep an eye on the connection indicatorsyssi esphome-jk-bms 2.0.0 vs 1.5.0.
I flashed 2.0.0 and placed the 2 esp32s further apart from each other and with wifi output_power set lower.
I think the main thing was to place the two esp32 further apart from each other and still on top of the BMS more or less. And turning down wifi output_power. Seems stable at least for todayAh, yes you maybe have to pick another BLE Protocol for some BMSs - and i´m on 2.0.0 since the release and there are absolutely no issues with the connection - would recommend you tu update and keep an eye on the connection indicator
Great if it works now - i had never a problem with two esp being too close togetherI think the main thing was to place the two esp32 further apart from each other and still on top of the BMS more or less. And turning down wifi output_power. Seems stable at least for today.
The BLE on the JK BMS HW v10 isn't that powerful. I could connect through my bedroom ~4m away through the window (and gips panels in the garage) using my smartphone and the JK BMS app to HW v11, but HW v10 has a lower range.Great if it works now - i had never a problem with two esp being too close together
These two ESPs are connecting through the through the concrete ceiling down into the basement
FYI there are serial numbers and email address of installer (assuming it's not yours) in some of the previous pictures you posted. Consider updating/obfuscating for privacy/liability reasons etc. I'm just pointing out, you do as you like of course.i have raised a ticket with Solis...
