Your power usage isn't going to be static with a mini-split. Once your set temp is reached it should use much less. However, the size of your rig, how well it's insulated, and the outside temp will all affect it. EER if I recall correctly is based on 95F / 50% humidity test conditions.If I go by EER, I'm using more energy than I produce with the assumptions I've made (7748 W•hr > 6206 W•hr). Since the OP has his working fine, that indicates to me I may be too conservative in my assumptions.
Thanks for the feedback. Good to hear I'm on track.Your conclusions look good with the exception of the 9000btuh units heating demand.
If you look at the specks on the above 9000btuh senville unit it states a 200 watt increase in demand while heating, something to note for 24/7 usage calculations. the 12,000btuh unit doesn't. This is very interesting to me, is it really that much more efficient?
Thanks for the feedback.Your power usage isn't going to be static with a mini-split. Once your set temp is reached it should use much less. However, the size of your rig, how well it's insulated, and the outside temp will all affect it. EER if I recall correctly is based on 95F / 50% humidity test conditions.
whynter elite 12000 BTU dual hose digital portable air conditioner
In my experience, probably not. I have a brand new LG 12,000 BTU 115v mini-split installed in the front bedroom of my 28 foot travel trailer. Even if I leave the bedroom door wide open, I have to use a Vornado fan to push cold air to the rear of the camper. I only have single pane windows so that hurts quite a bit. It was 90 degrees with 70% humidity this past weekend and it barely kept the rig at 74 degrees. I have a single 15K BTU roof-top unit that I have to kick on, too, to do the initial cool so that it doesn't take 8 hours to cool the camper down. This was the biggest 115v unit I could find anywhere. If I could have installed it near the middle of the camper it might be more effective.Can anybody tell me if a 9,000 BTU mini-split would be enough to cool a 35 ft motorhome in the heat of the desert? I've already got it half installed and I have to hit the road in 3 weeks. After watching this video and reading this discussion, I'm starting to doubt my choice. Is it necessary for me to go up to 12,000 BTU?
Depending on your layout even the 12000 might not be enough. We have a 38' 5th wheel and I am figuring 18000 to 24000 to do it. I do HVAC and Electrical for a living.Can anybody tell me if a 9,000 BTU mini-split would be enough to cool a 35 ft motorhome in the heat of the desert? I've already got it half installed and I have to hit the road in 3 weeks. After watching this video and reading this discussion, I'm starting to doubt my choice. Is it necessary for me to go up to 12,000 BTU?
Thanks a lot. I really appreciate that information.Good after noon, I'm currently running a 12,000 btu mini split in a 35' bus. It is 103F outside with humidity of 16% and about 77F inside. I would not expect this to work at all w/o window coverings and a fan, especially if i were to try to cool it down mid day in full sun. In other words of you like it at 68F and fast(er) do two 9000s one in front one in back. I still have to make a few insulation improvements and fill some holes so my extreme temp performance should go up
Thank you. I guess I misjudged big time. I have to scramble for a solution now.Depending on your layout even the 12000 might not be enough. We have a 38' 5th wheel and I am figuring 18000 to 24000 to do it. I do HVAC and Electrical for a living.
Thank you for that detailed information. I am checking out those curtains.In my experience, probably not. I have a brand new LG 12,000 BTU 115v mini-split installed in the front bedroom of my 28 foot travel trailer. Even if I leave the bedroom door wide open, I have to use a Vornado fan to push cold air to the rear of the camper. I only have single pane windows so that hurts quite a bit. It was 90 degrees with 70% humidity this past weekend and it barely kept the rig at 74 degrees. I have a single 15K BTU roof-top unit that I have to kick on, too, to do the initial cool so that it doesn't take 8 hours to cool the camper down. This was the biggest 115v unit I could find anywhere. If I could have installed it near the middle of the camper it might be more effective.
You're going to want to look into Magne Curtains to help block the heat, if you don't already have something in place.
If you have 240v in your trailer look at getting an 18k BTU unit. Maybe my situation is an anomaly. Hopefully others can discuss a better scenario.
I like every reply in this thread no matter if it is “works great!” - “doesn’t work”Thank you. I guess I misjudged big time. I have to scramble for a solution now.
it lets me evaluate my systems vs. uses
Yesterday it hit 105* outside of Sonora, Ca from 3-6PM. We ran the 4000w Onan for most of those hours to provide 1400 -1500 watts (plus surge) to the typical Dometic 13,500 btu rooftop unit.
that’s great. except for the noise of both the gen and the Dometic
We cannot stand that noise any longer
so we have decided to head down this mini-split path and see what happens
It also depends on other factors, like climate, direct sunlight, insulations, # of people in the space, cooking appliances used, including coffee pot.Thanks, you're right, it's $900:
LG - 12k BTU Cooling + Heating - Mega 115V Wall Mounted Air Conditioning System - 19.0 SEER
LG LS120HXV2 - 12k Cooling + Heating - 115V Wall Mounted - Air Conditioning System - 19.0 SEER2
Buy LG LS120HXV2 Today. Free Shipping. Check the LG - 12k Cooling + Heating - 115V Wall Mounted - Air Conditioning System - 19.0 SEER2 ratings before checking out.www.ecomfort.com
Just found another 12k at 120V ($768):
Klimaire 12,000 BTU KSIV 19 SEER Ductless Mini-Split Inverter Air Conditioner Heat Pump System with 15-ft Installation Kit and Wall Bracket 115V
And another one ($798):
PIONEER® DIAMANTE SERIES 12,000 BTU 20 SEER 115V DUCTLESS MINI-SPLIT AIR CONDITIONER HEAT PUMP FULL SET WITH 16 FT. KIT
Pioneer® Diamante Pro Series 12,000 BTU 19 SEER2 Ductless Mini-Split Air Conditioner Inverter+ Heat Pump Full Set 115V with 16 Ft. Kit
Pioneer® Diamante Pro series. Extremely quiet, highly efficient. Finally, an affordable 12,000 BTU 115V Ductless Mini Split Air Conditioner Inverter Heat Pump!www.pioneerminisplit.com
The space I have to condition is just 8' by 20' = 160 sq. ft. The 9k BTU units claim up to 400 sq. ft or even 500 sq. ft so I can't see needing to go to the 12k unit.
The problem with these unit is that they require 100-300vdc. They are heading in the right direction, but not there yet. Thanks. We need 24 or 48 vdc and 110vac as options.Just discovered a hybrid mini-split unit. It runs on DC and AC:
"This is the 5th generation of our ACDC12x solar air conditioner series with a new key feature we've had so many requests for - our new "C" model ACDC12C solar air conditioning technology requires no grid connection. Like previous versions, it also needs no batteries, no inverter, no charge controller - just plug in the solar panels and start saving up to 100% on daytime cooling or heating costs. A grid connection can be added to automatically allow operation at night, as well as to provide higher daytime capacity & uninterrupted operation during cloudy or low sunlight conditions. See ACDC12C Spec Sheet
During the day the ACDC12C can run exclusively on solar power with no AC power or grid connection when solar is strong enough. The maximum speed/capacity will be based on the level of available solar power available. If also connected to AC power source, the unit can run at full speed whenever needed, and will add in just enough AC power, if/as needed, while still primarily using available solar DC power."
