As far as i'm aware the only real advantage to series is minimizing the physical size and amount of wiring and connections you need to use. For example if i had 3 panels and had the option to wire all in parallel, or 2 in parallel in series with the other one as rburkat mentioned, I would only do that if it simplified something about the physical installation process greatly. Although putting panels in series will reduce the 'loss' in the wiring because of voltage drop, my gut feeling is that with only 3 panels that benefit would be immeasurable, while IF it did force you to add an extra length of wire or extra set of connections, that would be enough of a downside to dissuade me from it. Obviously the value placed on each factor changes as the total size of the installation grows. When you get to the point of 'needing' combiner boxes you are well into the point where wiring in series would reduce your cost and complexity of wiring significantly.
rbertalotto, i recognize you from youtube and tractor forums. Tip o' the hat to ya.
