So, I'm not really smart, but I'm also not too dumb. I've decided I want to build a 36 volt LiPO battery for my golf cart. I'm thinking, actually, I'll build 3 12volt batteries and put them in parallel, in the event I decide to upgrade it to a 48 volt system. But that's off topic, so forgive me. Obviously, the best cells for the job are prismatics and 180 ah is ideal, but not cheap. So, before I go screwing up 1200-1500 of otherwise good product, I decided to make life even tougher on myself and I'm first building a "trial battery", using the much less expensive/much less desired, NiMH cells that come out of the Ford Fusion. I picked up a pack of 21 cells for around $13.00 a cell figuring if I mess them up I won't feel AS bad. By buying the pack I also got some busbars, nuts, balance wires that came with it. Another digression. Anyway, my question is, if I build a battery out of this, 2p10s (the cells are probably around 23 Ah now since they're used), how will I charge it, if by chance it actually works? I've ordered a Tenergy hobby/rc charger for NiMH for each cell, but what to do later? If it was LiPO, I know the 10S BMS would serve as the balance charger, correct? Can I also use the same thing for these cells? I found a EV-Peak 12S DC charger on Amazon, but then I'd also have to add an inverter. Help? And please forgive the ignorance, I'm reading threads, watching videos, and learning on the go here.
