Thanks for that info! I had no idea. Will be checking out MT solar this weekend. I think my big challenge for tue ground mounts is going to be balancing out depth of the postholes vs location, as the the higher up the slope I go (I want to be on the high side for aesthetics), the closer I get to a huge amount of ledge (near-surface bedrock somewhat unique to New England). Gonna be putting a bunch of test holes into a perfectly good blueberry field come May, when it dries out a bit.55 degrees max tilt on the Sinclair.
I'll be happier with the MT Solar, higher height array which means less length for same number of panels, I get 4 feet ground clearance easily at the 65° tilt.
