Starfish Prime
- Oct 25, 2019
- 11
Hello, greetings from Hazel Green Alabama. I installed a Schneider Conext SW4048 with SCP panel to my Midnite Classic 250 and Big Battery 6KWh Lifepo4.
3KW of Trina pv panels.
Everything is working fine, making 240V split phase to my service panel and powering our 700sf tiny farm house. Very happy with everything.
However, I can't get the inverter to use the 120V that I'm sending to it from the generator. The supply is wired to the AC IN bus bars and grounded. The connections from the bus bars are feeding the AC IN connections into the Conext inverted. Multi meter shows 120-122 volts at both places. The AC IN/Generator support light on the inverter will not light up and power the house or charge the battery.
Is there a setting in the SCP that I'm missing? This should be a no-brainer but I can't get the Conext to use 120V supply from the genny.
Any help would be appreciated.
TIA!
Curtis
TIA!
Curtis
