aybabtme
- Apr 10, 2020
- 25
Yeah I'm 100% not suggesting that you rewire your boat . I wouldn't do it.From what I've heard from other Hatteras owners, it isn't worth it to try to rewire the whole boat. Not only is it a huge expense in coper and new parts, but you pretty much have to dismantle the whole boat. It's one of those quirky things about owning an old Hatt, kind of like the Whitworth wrenches you need if you have an old MG. Also, the original wiring is known to be top quality. Messing with it would definitely not increase the value of the boat.
The alternators and starters are also 32V. Sometimes an OEM starter is hard to find and it gets replaced with a 24V starter, which will work for a while, but they can burn up fairly easily. I would consider replacing the alternators and starters with 24V and have dedicated batteries for them, but for the rest of the boat, I want to keep the 32V system.
For heating/cooling, I think unless you have a ton of solar and a massive battery bank (for overnight), you're better off using a diesel heater or run the generator. My 38ft boat takes ~800W continuous to heat, and my battery is 8kWh. I could heat the boat (and use nothing else) for 10h before running out of power, and it'd take me 3 days to recharge the battery. A 53' boat probably need a lot more than 800W to keep warm. I'm using a resistive type of heater and my boat isn't really insulated, it might work better if you heat using a marine AC in reverse cycle, and maybe the Hatteras have been built with isolation? I don't know.
You have a genset so I'd count on it for the heating/cooling. Unless you have a pretty big solar install and a bank big enough to last through the night. That would really be the ideal, but it gets expensive. Alternatives for the heating is to do it per-cabin, and to use heating pads at night (no need to heat the whole boat when you just need a warm bunk). I haven't done this yet, because it's not high on my priority list, but that's probably the strategy I would adopt for heating. For cooling, I'd make sure my installation allows me to cool down individual cabins independently.
Btw 1500kWh per month is 50kWh per day. That's really a lot! What do they do to use so much power on a boat?
