Looks like Ian just dropped the price from $2800 to $2200 for the 10k. @Watts247 - Ian Roux any more news/videos out for these units?
This one is more similar to the solark. It has a biderectional grid input/output and a backup output.Need to think things through as I am wanting to prepare to sell back to grid but also want to have power to the house when the grid fails. The scenario goes something like this. There is a central meter pedestal that used to supply power to a mobile home and shop. The mobile home is no longer used and those lugs are now feeding the new house, that is approximately 100' from the pedestal, with a 200amp service, while the other lugs on the pedestal still feed the shop which sets about 30' in the opposite direction, with a 100amp service.
All solar gear resides and will remain in the shop.
With SolArk, the main lugs of the pedestal could be ran to the shop, which requires feeder wire size be increased to handle the 200amp service. The SolArk would feed a main panel in the shop, with one breaker in that main panel feeding a shop subpanel, while the rest of the power goes to the house. This would be a new home run also requiring 200amp feeder cable. The ct's would be placed in front of the main panel to allow the SolArk to back feed any excess to the grid. In this manner, if the grid goes down the SolArk stops feeding the grid but the house and shop remained powered.
With something like the NHX 10k or SRNE10k ... No new feeder wires are needed. The unit will feed power to the shop from output Load1 and push excess back to the grid, but when grid goes down, so does power to the house.
Am I cooking with gas or lost???
I'm not sure on the W247 NHX.Need to think things through as I am wanting to prepare to sell back to grid but also want to have power to the house when the grid fails. The scenario goes something like this. There is a central meter pedestal that used to supply power to a mobile home and shop. The mobile home is no longer used and those lugs are now feeding the new house, that is approximately 100' from the pedestal, with a 200amp service, while the other lugs on the pedestal still feed the shop which sets about 30' in the opposite direction, with a 100amp service.
Your srne can sell back to the grid?I'm not sure on the W247 NHX.
I haven't used the grid sell back feature on my ASF. The only way I know the power is out is if I hear my neighbors generator.
Make sure your provider approves whatever unit you choose to sell back... Some have a list of approved models.
Oh wow. Didn't know it had that function. Very cool.
Thanks for posting this. I appreciate that the video showed some grid interactive features but I still think the focus was a little too much on off grid capability when the real market for this should be retrofit applications and grid interactivity.Ian has a video up on the NHX inverter. I need that solar awning as well.
It doesn't need to bump up the frequency. It can't. Grid is too strong. It bumps up the voltage a bit. It uses the CTs to sense the home loads and supplies those from battery or pvWhere electricity goes for dummies please.
Graphic from the NHX manual linked from Watts247: When configured like this the nhx can feed both home loads and grid, and it does this by bumping up the hz a small amount above grid value. Where does the excess power the nhx feeds past the ct's go; grid, home, both and how is this determined?
x
Correct. So without the CTs the excess pv would flow to the grid, but any active home loads would use the power first.Home loads and grid are both connected to 'grid' on the inverter.
Yeah, that diagram doesn’t make much sense to me either. I would think the CTs would be by the main breaker if concerned about sending power back to the grid/zero export.Where electricity goes for dummies please.
x
Oh, I see. Where it is it can't see the power flowing to the main panel?Ok ... yeah ... no ... nope. I don't get it. The CTs are before the split of home load/grid. Wouldn't the CTs just say this is how much current is either coming in to, or going out of the inverter? How does the inverter know if the electrons are making a left or a right after the home load/grid split? Maybe a link that goes into more detail?
Dude ... you had me scratching my head. My understanding of things electric actually did start with a butter knife in an outlet (darn lucky the knife was too large to make contact and mum put an end to it), it hasn't improved much since then.Oh, I see. Where it is it can't see the power flowing to the main panel?
